Is Grafana 7.0 missing row color modes?
Trying to recreate Grafana 6.7 tables in Grafana 7.0 and I don’t see an option to color an entire row based on thresholds applied to a given cell, as was previously possible. See Thresholds → Color Mode in the following image:
Is that still possible? And, side-question: would it be possible to color the row based on a string in another column? E.g. row should be red when Result cell is FAILURE and green when green when result cell is SUCCESS.
I have the same problem. I can only apply color to one field / column not the whole row.
It seems to be one of several things that the the old table panel could do that the new one cannot (at least not yet). Personally I am just continuing to use the old table panel in v7 (via cut/paste) until (I hope) the new table panel can do everything that the old one could…
I love the product but most people would expect a newer version to be able to do what an old version could and more. With v7 the table panel does have some improvements but is a backward step in a lot of other ways.
Good thing we still can duplicate old tables, hope devs will see this thread.
Is there a github issue where we can track this?
