Grafana 11.3.0 linux 8 -
I am trying to get a list of AWS/SQS cloud watch queue metrics named ApproximateNumberOfMessagesVisible to be summed and change the status of an icon on a canvas dashboard from green to red when a target is reached. -
First, I am able to get the icon to change from green to red on the dashboard on a single target, but I cannot sum from multiple AWS/SQS queues.
I am also using the override option under the canvas, icon and setting the threshold to 100 red and base to green. Further I am using the Fields with name option to reference either the label1-label4 or the alias I set up under transformations(NEWTOTAL).
I am using the transformation Add field from calculation, Reduce row, Operation: label1, label2, label3, label4, label5
Calculation: total
Alias NEWTOTAL
- What happened?
When I use a single label, for example label 1, the icon changes color correctly based on the threshold.
When I use the Alias, the icon remains green.
The icon should change to red when the threshold is reached. -
“datasource”: {
“type”: “cloudwatch”
“uid”: “Cloudwatch”
“dimenstions”: {
“QueueName” “testqueue”
“expression: “”',
“hide”: false,
“id”: “”,
“label”: “label1”,
loggroups”:,
“matchExact”: true,
“metricEditorMode”: 0,
“metricName”:ApproximateNumberOfMessagesVisible",
“metricQueryType”: 0,
“namesppace”:“AWS/SQS”,
“period”: “”,
“queryMode”:“Metrics”,
refId": “AF”,
“region”: “associated region”,
“sqlExpression”: “”,
“statistic”: “Average”
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. no
I have tried this… listed below
Summing all fields matching certain pattern - Grafana / Dashboards - Grafana Labs Community Forums
