Currently, I am having incorrect math operation from AWS Cloudwatch Ops through Grafana dashboard.
I need to get the failure rate for AWSBackupJobs.
I set:
$A → NumberOfBackupJobsFailed
$B → NumberOfBackupJobsAborted
$C → NumberOfBackupJobsCreated
So, I put ‘(($A + $B) / $C) * 100’ in the math expression column in Grafana dashboard.
However, when I tested the expression with different constant numbers, it does not give correct results.
For example, if you put ($A + 5) / $C * 100 as a math operation, the panel (failure rate for AWS BackupJobs) always gives 0.
Do you know why the ‘’(($A + $B) / $C) * 100’’ operation does not work out when dealing with CloudWatch metrics in Grafana?
I guess because your A, B, C produces timeseries and not single numbers.
I would use CloudWatch math instead of Grafana expression + long Period aggregation (e.g. 365d instead of auto), so you will get single number results from A,B,C queries.
Can I ask you why if I make 3 single expressions with 1.($A) 2nd ($B) ..etc it shows the correct value in it but as soon as i put them in one equation I get a wrong value?
Thank you for the explanation. is it possible to load the current content in a variable to it is kind of static?
