I have no problems getting my panels to work when I query for cloudwatch ECS data. They display properly. However, when I try to do any math expressions on them, it breaks and throws the Query Error seen in the pic attached. My queries work as long as I don’t include math expressions. This worked in version 8 of Grafana, I had many dashboards break, and all of them had math expressions. What could cause this?
Edit: Formula doesn’t matter, adding math field breaks visualization
@jangaraj
Thank you for your response. However, I still fail to understand it. So, I can’t reference my fields with “$A” or “$B” because my fields are “A” and “B”, right? Then, how am I supposed to reference them? I tried renaming the fields with a dollar sign upfront, but that didn’t work. How do I actually do what I want in this case? Thanks.
No, your $A*100/$B is Grafana expresion. But don’t use Grafana expression. Use CloudWatch math. CloudWatch math (math calculated by ClouddWatch) != Grafana expression (math, calculated by Grafana), be familiar with these terms:
Got it. Check your (debug) logs and spend time to narrow why expressions are not working based on Grafana server logs/traces (of course read also release notes, breaking changes - blind guess: data format is a problem).
IMHO it’s not worth it to debug why expressions are not working - just use CloudWatch math and you will be safe between any Grafana upgrades, because CloudWatch will be doing whole calculation.
