Grafana v10.1.4 (a676a96d91)
Debian
- What are you trying to achieve?
I want to have the EFS bandwidth percent usage thanks to these queries :
- How are you trying to achieve it?
I have no problem to add the Cloudwatch metrics PermittedThroughput and MeteredIOBytes, but when I try to set (m1/1048576)/PERIOD(m1) I have an error.
Error is :
“metric request error: "ValidationError: Error in expression ‘queryfb003148d6a3456bb93bcaaf27a40534’: Unsupported operand type(s) for PERIOD: ‘[Array[TimeSeries]]’\n\tstatus code: 400, request id: 070e0d09-31f7-4345-8074-d94bd48723ac"”
I have the same error if I try to use function TIME_SERIES. I did not try others.
- What happened?
I don’t understand why, because if I use another function like SUM, LAST, it works. Moreover in the field there is autocompletion and function PERIOD is proposed. All the functions in Use metric math - Amazon CloudWatch are proposed.
I want to use the function PERIOD
- Can you copy/paste the configuration(s) that you are having problems with?
I can send code if needed, adding attachment is disable for new users ![]()
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
In UI, I get the error :
