So I would need to sum all fields matching a pattern. So for eg. I have fields apples.sanfrancisco: 10, apples.newyork: 15 and apples.miami: 100 and I would like to sum all these together with the pattern apples.*, so apples.*: 125 but this does not work. How could this be done? I’m using elasticsearch.
I think this is possible by using the Transform “Add field from calculation”. Then select the tables you like to add and use the Math operator (e.g. Sum) to get the final result in the form of a new table.
Please have a look at the attached screenshot for reference.
Hi @usman.ahmad ,
I have explored this option but unfortunately this is not feasable for my situation since the fields that come from the data are not known/there are too many of them so I can’t possibly manually do anything like this. The only thing I could use is the pattern they come is at it stays the same.
