Slack contact points failed
I have multi contact points with Slack app on my opensource Grafana system.
Some of them are working and some stopped last week.
I replace the webhook urls and test it seems to be fine with the test but on a real alert there is no notification.
I’m getting this error from Grafana after trying to test the contact point
Failed to send test alert.: failed to send Slack message: failed to send request: Post XXXX unsupported protocol scheme ""
from Grafana logs
logger=ngalert.notifier.slack notifierUID=rQe7NE3Vk t=2024-07-01T12:06:33.589073569Z level=error msg="Missing receiver"
logger=ngalert.notifier.slack notifierUID=rQe7NE3Vk t=2024-07-01T12:06:33.589190066Z level=error msg="Missing group labels"
logger=ngalert.notifier.slack notifierUID=rQe7NE3Vk t=2024-07-01T12:06:33.58972836Z level=error msg="Failed to send Slack message" err="failed to send request: Post \"XXXX": unsupported protocol scheme \"\""
logger=context userId=1 orgId=1 uname=flkmonitoradmin t=2024-07-01T12:06:33.589984284Z level=info msg="Request Completed" method=POST path=/api/alertmanager/grafana/config/api/v1/receivers/test status=207 remote_addr=192.168.21.1 time_ms=38 duration=38.667011ms size=707 referer="https://192.168.21.125:3000/alerting/notifications/receivers/Usage-API/edit?alertmanager=grafana" handler=/api/alertmanager/grafana/config/api/v1/receivers/test
Version v10.0.3
Any idea?
Thanks
Did you followed doc properly?
Hi @jangaraj Yes I did.
I follow this doc and I needed to create new slack app and not using old incoming webhooks.
I fixed the issue it was Slack side.
Thank you!
