Alerting thru Grafana 4.1.1
Hi guys am newbie to grafana, although I’ve installed it on an instance and when I try to configure alert and send test it throws me the below error:
t=2017-04-28T14:44:43+0000 lvl=info msg=“Sending notification” logger=alerting.notifier type=slack id=0 isDefault=false
t=2017-04-28T14:44:43+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=0 notification=TestAlert
t=2017-04-28T14:44:43+0000 lvl=eror msg=“Failed to send slack notification” logger=alerting.notifier.slack error=“Post https://hooks.slack.com/services/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: read tcp 172.17.0.3:52197->172.17.0.1:443: read: connection reset by peer” webhook=TestAlert
t=2017-04-28T14:44:43+0000 lvl=eror msg=“Failed to send alert notifications” logger=context userId=1 orgId=1 uname=admin error="Post https://hooks.slack.com/services/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: read tcp 172.17.0.3:52197->172.17.0.1:443: read: connection reset by peer"
t=2017-04-28T14:44:43+0000 lvl=eror msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=POST path=/api/alert-notifications/test status=500 remote_addr=172.17.0.1 time_ms=1ns size=48
###please help out if anybody familiar with this, thanks.
Is your instance behind a proxy? That log shows that the instance is trying to connect to 172.17.0.1:443 which isn’t the IP of hooks.slack.com
Yes It is ,how do we fix it if that is stopping it ?
It appears that the proxy is not working properly, you’ll need to sort that out or stop using it.
i mean yah there isn’t a way i could stop using it maybe i should sort that out ? or use some other proxy internal to our company ?
