If not possible, this is a suggestion.
When using the Graph Panel, is it possible to show the values of the data points (and not just a dot) for each variable? Ideally with series override, because one might not need to show the values for every series.
I know the Gauge panel allows that, but it works only with bars. My need is for a mixed chart with bars and lines.
Or is there an unofficial plugin that does that?
