Hi!
Is there any way to show the values in a Graph, above bars or points in the graph?
I have same problem with this kind of graph. The values only are showed with tooltip. did you solve this problem?
Mine is looking the same today.
Did you try to set it up like my picture?
You can see values only on âBar Gaugeâ
As long I am not able to figure out a better solution, I have 2 graphs in a row for same data. First has hours and good trand view and from the second I can see the values quickly.
Waitig for a better solutionâŠ
Is there a way to put the time values on X axis?
Thanks, but itâs not what i meant.
I meant to have the timestamp value â2020-04-27 18:00:00â instead âhourly stat. Meanâ
I would love to see this also, but have not found a way. Found ca 10 topics in community forum asking for this, but zero solutions. I was suggesting the best i have figured out myself - have 2 graphs lined up like in one of my pictures above.
Look trendline and time from first and see values from second.
I think I created an issue also in github in January about this, but no answer.
DonÂŽt forget to share, if you figure out somethingâŠ
Sure. But iâm afraid that deploy team have to fix this. Hoping for a solution too (it would be enought to publish the values on bars on a chart panel).
+1 Hoping for a solution too
+1 Hoping for a solution, a bit silly that this is not possible.
+1 Hoping for a solution or workaround with âGraphâ elements
If I understand the issue correctly, I posted my solution in this thread:
Esperando por uma solução também
+1 Hoping for a solution too, this is quite basic
any news? need also the values over a barâŠ
It seems like a simple problem to solve. Iâam hoping for a solution too.
looking for solution too !
