Hello All: New Bar gauge does not show series time (hour) like the old Bar Graph did. Can not seem to figure out a way to have the same.
OLD
NEW
Any help is greatly appreciated. Thanks
Grant: Thanks so much for the tip. I had not thought to try the time series. Looks functionally equivalent except for the totals at the top of the bars. Can those be added with a transformation? Will try that. Anyhow: super thanks for the help.
Yes, you can add (sum) the values at the top of the bars using a Transformation (no Flux required…even though I’m sure it can be done that way too).
