What Grafana version and what operating system are you using? → Grafana Cloud with InfluxDB_SODA
What are you trying to achieve? → a bar chart that counts how many times individual values appear.
How are you trying to achieve it? → I’ve duplicated one of my time series and set it as a Bar Chart and tried a couple variations to try and format it the way I want it but have been having no luck.
What did you expect to happen? → I want the “Seq 1 Shutdown” to be on X axis and count on the Y axis. Time shouldn’t be part of this visualization.
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. → it keeps formatting time on the X axis.
The state is at 0, and it’s counting 1 every time it appears, but it’s not totaling the count.
I attempted to create another template on SODA where the parameter is on change instead of finding the state every 10 seconds but that doesn’t yield any responses:
I’ve seen solutions online for uploading a flat table and creating a bar graph that way, but I need the graph to be live and updating along with my dashboard.
