Same data, different graphs. I want to see numbers on upper graph, can not figure out how. Or have time instead of custom text “Vahvel” under each column in the lower graph. I have seen several similar topics around with 0 answers.
Any hints? for me no difference to use the Bar Gauge or Graph…
When you hover on the green graph and enable points from visualization style . Don’t you able to see the value.
One more thing make your howver shareable so that when you will hover on 156 you can see the value at that same time on the green graph. It will be shareable tool tip and hover
If I move with the mouse on the column,then I see the value of this column. I would like to see all values as my red graph below.
One more thing make your howver shareable so that when you will hover on 156 you can see the value at that same time on the green graph. It will be shareable tool tip and hover.
I did not understand this…
