Hi - I am new to Grafana.
I do not understand, how the “Alias or Regex” field for Series overrides work.
What I want is basically the same as has been asked on this thread
I have two queries:
the first should be displayed with parameters different to the second - heres my overrides:
Strings that I have tried to input into the Series overrides ‘Alias or reges’ field:
Bor/B/or/.*B/- the name of the Queryregistration_idor/registration_id/or/.*registration_id/- the name/alias of the id field
Trying to add some hacky looking platform || "registration_id" as "metric" into the queries doesn’t work either, this will just get the following error
column metric must be of type CHAR, VARCHAR, TINYTEXT, TEXT, MEDIUMTEXT, LONGTEXT. metric column name: metric type: INT but datatype is
If however I input /.*/ into the ‘Alias or regex’ field, the overrides of course work - but both for the first and second query.
Against what exactly is the ‘Alias or regex’ field even compared?
What do I have to do to make the override work with the second query only?
