8.4.4 on docker -
Change the series style to Bar in the timeseries graph for several queries by using a regex-overwrite. -
By using regex
What happened?
Nothing, all graphs are still shown as Lines. -
The temperature graphs ‘TempNick’ and ‘TempWZ’ to be displayed as bar-graphs. -
These are the queries in place:
SELECT
ts/1000 AS "time",
val AS 'WP'
FROM ts_number
WHERE
$__unixEpochFilter(ts/1000) AND
id = 48
ORDER BY ts ASC
SELECT
ts/1000 AS "time",
val AS 'TempNick'
FROM ts_number
WHERE
id = 71
ORDER BY ts ASC
SELECT
ts/1000 AS "time",
val AS 'TempWZ'
FROM ts_number
WHERE
id = 73
ORDER BY ts ASC
No -
Configure field overrides | Grafana documentation -
Observations
When using Override option ‘Fields with name’, the only possible selections are
Thus I’d assume the regex should be able to filter on excatly those, but:
- When I change the regex to .* all 3 queries are displayed as bar-graphs.
- When I change the regex to .*W.* all 3 queries are displayed as bar-graphs.
- When I change the regex to .*WP.* nothing happens.
- When I change the regex to .*Temp.* nothing happens.
- When I change the regex to /.*Temp.*/ nothing happens.
- When I change the regex to /Temp.*/ nothing happens.
- When I change the regex to Temp.* nothing happens.
When I try the same in play.grafana.org by adding XX to some querie aliases it works with pattern XX.* !
Any ideas what’s going wrong?
Thxs
