Display name overrides with Regex not working
I’m trying to override display names with a matching regex. This is what I’m trying to achieve:
${host} Temp[0] → Sensor 1
${host} Temp[1] → Sensor 2
I tried a name override, which works fine. However, the variable ${host} changes, e.g. “host1”, “host2”, so a name override is not possible. I think I need to use a regex override, but what I did does not have any effect.
  • What happened?
Nothing, the override doesn’t work.
Change of name from “${host} Temp[0]” to “Sensor 1”.
See image above.
No.
I have the same issue and don’t know how to fix it.
Maybe you must try with the host name included in regex, like “host1 Temp[0]”.
I had this problems yesterday and i solved with a regex that contains all possibilities. In my problem I would like to math all status 400 and my entries was “POST Status 404”, “GET Status 403”, etc… So I first try this regex “Status 40[0-9]” but it doesn’t seem to work so I try with all possibilities in regex like this “GET|POST Status 40[0-9]”.
I hope this can helps you
Guessing you probably have to escape those brackets with something like Temp\[0\] . Additionally, I tend to have good results wildcarding things with .* such that I think this will work with something like .*Temp\[0\].*
