Same Dashboard not the same version on two devices
I run a grafana server on an Ubuntu LAMP-System.
I have some temperature sensors that write to InfluxDB and are visualized with Grafana.
I created a Dashboard on my Linux laptop with Firefox with two graphs. All fine.
I look at that Dashboard (same name) from my Android mobile with Chrome and it shows an older version with only one graph but with up to date data. Reload doesn’t change a thing.
I assumed some caching stuff and passed the URL to Firefox on the Android that I normally do not use on the Android - STILL THE SAME ONLY ONE GRAPH???
I’m completely clueless now and appreciate any idea how to debug/advance here.
Thanks
After playing around a little bit: is it possible that for some reason “Apply” when editing a graph does not save the dashboard as well?
But when I hit “Apply” no “Save”-Button is visible any more. I have to go to the settings to safely save the dashboard.
User error or UI mishap?
Yes, you have to “Save” (not “Apply” only) dashboard - that will save changes in the DB.
Thank you.
I was on 10.4, upgraded to 11.3 now. I see that the behaviour of the save buttons changed and makes more sense to me now.
