I’m very new to grafana.
when i watch youtube videos i keep seeing that there is a query builder.
it is not visible.
Maybe someone has asked this question before but I can’t find it.
i am using 7.3.4 / influxdb / Umbuntu / docker
thanks
what vesion are you refereing to?
the editor is not as in the screen shot
regards
Can you share what options are missing in your query editor? Perhaps a screen-shot.
is the problem now resoved?
Now,
This is a screenshot from what I should get
This is missing.
Only the option for making a query by code is there
Best regards tom
what happens when you click on options?
which one do you mean
can you install version 6?
Hi Tom,
Did you add your data source and selected it when adding/updating query? Here is a topic with more information: https://grafana.com/docs/grafana/latest/panels/queries/.
Try clicking the Edit icon.
hello,
Clicking this has no effect, nothing is opening.
regards
Weird. I am unable to replicate that on Grafana Play. Please file a bug report in grafana/grafana.
Also, if you are in the public Slack, post this in #grafana-fails.
O I’m very new in this area
Please explain we’re to get the bug report so logfile
Sounds very much like the problem I ran into a couple of years ago.
Suggestions:
Try a different browser
Make sure your browser is a recent release
Try reducing the width of your browser window
Regards,
Antony.
Hello Antony,
Don all of that
Regards
Yes the data source is connected I can make a query.
I can make a query in code but not via the builder as in all the examples
Nog I make one in influx and then copy the code, this works but I want to do this via the grafana builder
Regards
