Query editor missing
Hello canyoncf60,
I’m experiencing the same problem with the query editor as it is also missing in my grafana’s 7.4 installation. It happens in both Firefox and Chrome. It allows me to write code query but no chance with the query editor.
Have you already fixed it?
Thank you all for your kind answer.
Best regards
Just a stab in the dark here, but I noticed that you’re using the Flux query language (not InfluxQL). Meanwhile, the screenshots you show, and the discussion in the thread appear to be about the InfluxQL query builder. That won’t be available for a Flux datasource.
Based on New in Grafana 7.1: Gain new data insights with InfluxDB and Flux query support | Grafana Labs there should also now be a builder for Flux queries, but perhaps the way to pull that up is different from the old/classic builder for InfluxQL?
Thank you Svetb for your kind reply. Apparently,the query editor is available on InfluxQL (as you mentioned).
Thanks a lot!
Hi my data source is influxdb and the language is flux. Maybe that’s where the problem is
Oh, I face the same issue and was wondering why…
Thanks!
I have now seen the " Query Language" option in the data Sources configuration.
This can help:
delete the variables on ‘datasource’ of the JSON content
      "datasource": {
