Query editor missing in Enterprise edition?
    Grafana v9.4.7 Enterprise on Windows 10 22H2 (without any licensing)
    Grafana v9.4.7 OSS on Windows 10 22H2 (without any licensing)
    Create dashboards with InfluxQL queries
    Adding a new dashboard, then a new panel
  • What happened?
    The query is only available in raw format, no query editor (enterprise edition)
    The query editor is available in OSS edition
    Query editor to show up in enterprise edition as well.
    Standard grafana installation without modifications to the config.
    Grafana started from command line (both started on command line but not simultanous)
    n/a
    n/a
