I’m using Grafana Enterprise on a Ubuntu Server 64 bit on a Raspberry Pi 4.
When I installed Grafana I’ll get the version 9.3.4. It’s installed in combination with InfluxDB 2.6.1 and Telegraf 1.25.0.
This was the perfect constellation - everything works fine. On Wednesday this week Grafana was updated to 9.3.6. First everything seams to be okay, but today I tried to change something in one object. So I cklicked on edit.
Problem: In version 9.3.4 I saw the queries in an editor direct under the header for the query
In the edit view of version 9.3.6 the header of the query seams to be expanded but there is no editor!
When I now click on the header to collapse it the query is in the header!
If I would change something in the query I had to copy / generate it new and insert it into a new query and must delete the old one.
Can you please fix it?
