Public Dashboard - Unauthorized Popup
I installed newest version Grafana 10.2.0 to get the Public Dashboard feature in order to embed charts in different web pages.
As long as I’m logged into Grafana => no issues.
Then logout and open the link from the public share dialogue
  • chart is loaded, data is available => no issues
  • after 5-10 seconds an Unauthorized Popup occurs for any public shared Dashboard
Looking into Developer Tools from browser this is caused by/api/frontend-metrics call which returns status 401.
This is pretty annoying but I cannot find any configuration to prevent / disable this call.
Any hints for configuration / setup to avoid this behavior?
Hello @weymann,
I’ve observed a similar anomaly on my public dashboard, which appears to be stemming from a call to /api/frontend-metrics. The development team has successfully identified the problematic code, as documented in this GitHub issue: Task: avoid Unauthorized frontend-metrics call when it's a public route · Issue #76995 · grafana/grafana · GitHub.
To address this issue, a pull request has been reviewed and merged (see [v10.2.x] Identity: Fix org role none comparison by grafana-delivery-bot[bot] · Pull Request #77001 · grafana/grafana · GitHub). The forthcoming release, v10.2.1, is slated to incorporate this resolution.
Best regards
Thanks for this info.
Searched a lot in grafana config what could be wrong but didn’t found any hint.
I’ll wait for next version and check it!
No problem. I just noticed that Release 10.2.1 (2023-11-14) · grafana/grafana · GitHub has been released, and the problem has been fixed on my machine.
Also updated version and working for me too!
When will this update be applied to Grafana Cloud? Had this issue for over a week, still present.
looks like with the recent updates the issue reappeared.
Never had it before and now I have the exact same issue after updating Grafana to 10.3.3. Happens only in Chrome/edge etc. In Firefox works ok.
It continues to occur in 10.4.1. The browser is Chrome.
After 10 minutes of displaying the dashboard, scroll down to see “unauthorized” and then the screen will become the login screen.
I also had this problem on Grafana v11.1.0.
I fixed the problem by changing the “token_rotation_interval_minutes” variable in the configuration file from 10 to 60 minutes.
Well, or at least it occurs much less often and does not interfere with working with dashboards
10.4.9, still have it.
It’s also still present in the latest 12.2 when using certain visualizations that request annotations… For example the Business calendar plugin.. I created a github bug report for that: Public Dashboards: Unauthorized Popup issue is still present with certain visualizations · Issue #111619 · grafana/grafana · GitHub
