Unable to create Public dashboard
Hi all,
I am having some issues with making dashboard public. Here is the needed information and thanks to all for the support:
    v.10.1.4, self-hosted on VM
To share a dashboard with external organization, without the need of authentication.
To make the dashboard public
  • What happened?
I already got familiar with the documentation - Public dashboards | Grafana documentation and even make a record in grafana.ini to enable Public dashboards - publicDashboards = true
I am expecting to have “Public dashboards” button after “Share” button and to have generated unique URL:
I did - Public dashboards | Grafana documentation and even make a record in grafana.ini to enable Public dashboards - publicDashboards = true
Thank you!
Regards,
Stefan
Same problem
Which version do you use? This feature is enabled by default in 10.2-10.4.
May be in 10.0 and 10.1 it should be enabled via grafana.ini:
[feature_toggles]
Could you check that this feature is enabled in Administration - Settings page?
Admin
I updated to the latest version of Grafana OSS and the “public dashboard” tab appeared. thank you!
