Hello
I’m using Grafana Faro with Grafana Cloud. I’ve awesome dashboard (provided on screenshot)
How can install this dashboard my Grafana on-premise? (my current version is 12.0.0)
It is not a dashboard but application. Based on doc:
It’s only a Grafana Cloud feature, so you can’t install it.
But you can mimic it. Just explore query used in each app panel and use the same query in your on-prem dashboard. There are some third party dashboards for that, e. g. Grafana Faro - Frontend Monitoring | Grafana Labs but they are not maintained bu their owners, so dashboard queries may not be 100% correct. They are at least good start to save a few clicks in the UI initially.
