Hi! We have our own instance of grafana oss (that is, we aren’t using the cloud service). I’ve configured the frontend to initialize the faro web sdk and I see requests going out, but I don’t see any frontend/faro data in the Grafana UI. It could be that I don’t know how to query properly, but I don’t see any relevant metrics in the metrics dropdown in Prometheus. Is there documentation on how to configure the backend to display the web vitals metrics?
Also, is Grafana Faro fully supported on a custom install or only in the cloud?
“@grafana/faro-web-sdk”: “^1.0.2”
not sure about backend -
Submit grafana faro statistics from front end to backend and view in grafana ui prometheus or anything. -
We’re hosting our own instance of grafana, agents, etc.
on front end:
import { initializeFaro as coreInitializeFaro } from '@grafana/faro-web-sdk';
export function initializeFaro() {
const faro = coreInitializeFaro({
url: '/foo/app/collect',
app: {
version: '1.0.0',
faro.api.pushLog(['Faro was initialized']);
return faro;
What happened?
I get a 200 response from the grafana endpoint with a response body “ok”, indicating that the data is being submitted, though I don’t see any indication of this in the server logs. Going into the grafana ui / Prometheus, I’m unable to find any UI related data. There are no relevant metrics in the metrics dropdown, they all relate to backend metrics. -
I’m expecting to be able to query UI Web Vitals and/or other data provided from our app frontend in Prometheus.
…something as shown in introducing-grafana-faro-oss-application-observability -
app: {
version: '1.0.0',
return faro;
no everything looks good -
Grafana Faro Web SDK architecture | Grafana Cloud documentation
Grafana Cloud Frontend Observability | Grafana Cloud documentation
