I want to be able to view the Frontend Observability dashboard in Grafana cloud that I have previously can view 2 week ago.
I want to be able to view the Grafana Frontend Observability log in Grafana cloud -
Open Grafana cloud trying to find Frontend Observability tab on the left -
What happened?
Unable to find Frontend Observability tab on Grafana cloud
Unable to view Frontend Observability dashboard on Grafana cloud
Unable to view Frontend Observability log on Grafana cloud
Expected to see Frontend Observability tab on Grafana cloud
Expected to view Frontend Observability dashboard on Grafana cloud
Expected to view Frontend Observability log on Grafana cloud -
non -
I seeing 2 alert
Grafana Cloud Tempo is Experiencing Minor Service Outage. Follow this incident on our status page in the grafana.com / orgs / username page
and in the page that use to have the dashboard is not warning that You have reached your free tier limit for Frontend Observability. Upgrade to Grafana Cloud Pro to track more sessions. -
None
Not sure if this is due to the outage or due to the usage limit.
