Hello Community,
I have installed Grafana locally on my Windows Server 2022 using the following link:
After the installation, I logged into the web interface and tried to add my database connection. However, I am only getting error messages.
Here are the details of my database configuration:
- Type: Microsoft SQL Server
- Host: IP Address
- Database: Database Name
- TLS/SSL Auth: false
- Authentication: SQL Server Authentication
- Username: Grafana
- Password: password
I have left all other settings as default.
The user has the following permissions:
VIEW SERVER STATEVIEW ANY DEFINITION
The database is configured to allow both SQL Server and Windows Authentication modes.
Except for the user permissions, all settings correspond to the Windows default settings.
I would appreciate your help with troubleshooting this issue!
Thank you in advance!
