10.2.2 -
Get data from database -
I connected the MSSQL to Grafana, but for some reason when I select the database, I am not able to acess to the tables on it. -
What happened?
For some reason I am not able to get the tables in the database, I thought that was a problem with the permits in the database. I gave the permits to the user, but it not works. -
I expected that was the permits on MSSQL. -
I did not receive any error. -
Microsoft SQL Server data source | Grafana documentation
Welcome @jlara
Does the user you used to create the data source have access to the database and tables?
Hello @yosiasz, thank you. Yes, the user has access to the databases, tables and I am able to enter directly to MSSQL, but for some reason when I tried to get data using Grafana just show me only tables, I was using windows authentication mode.
Other option that works for me was using a SQL login, and it works, I did not understand if there are action that skipped by my side, but I am still investigation.
Thank you for the attention.
