hi,
I’m having trouble to get the data from mt DB se attach images:
and
while trying to get data from any DB this what im getting -
need help with that
thanks
Gaston
hi,
and
need help with that
thanks
Gaston
Check out what the log file says.
You have grafana service running as the windows user you are using for the data source authentication?
yes the service is running
the question was not if it is running but rather Do you have grafana service running as the windows user you are using for the data source authentication?
Is grafana installed on Windows?
Looks like the answer is no. Its running as local system
how can i pass my data on this way?
can you assist me with this?
