MSSQL Linked Server DataSource Syntax in Grafana
    Windows 2019 Data Server - Grafana 9.4
    Configure a datasource in Grafana that connects to a linked server in MSSQL vs the default databases.
    The syntax in the datasource connection screen.
  • What happened?
    The linked server datasource configuration returns, "cannot open database that was requested by the login.
    I’ve been testing different linked server connection strings in granafa without success.
    Underneath the MS SQL Datasource connection. I’ve added the user to the allowed permissions under MSSQL permissions for linked server and have been manipulating this string in attempt to connect to the linked server. If anyone is unfamiliar with linked server I posted a link below.
    [LINKED_SERVER].[CATALOG].[SCHEMA].[TABLE_NAME]
    No errors are listed in the logs and no instructions listed in the error.
For reference this is a link to the MS SQL Linked server. I’ve linked to an Oracle DB.
Create linked servers - SQL Server | Microsoft Learn
Screenshot 2023-06-05 185347
When I attempt to connect this is the return message.
login error: mssql: Cannot open database “[LINKED_SERVER].[CATALOG].[SCHEMA].[TABLE_NAME]” that was requested by the login. Using the user default database “master” instead.
My at a loss. I’ve added the spc account to the linked server with permissions as an impersonator in SQL as well as making it the security context.
Any clues would be appreciated.
What do you see on the sql server security events service. It should give you a hint
