Grafana dashboard data to MS SQL Server table
Can Grafana dashboard data be mapped to a MS SQL Server table? What is the best approach for this?
GRAFANA FORUM’S 3 BEST PRACTICES:
  1. Please post inside a subcategory
  2. For questions and advice, please try to use the template below
  3. If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
  • What happened?
