Hello, I have created a table in grafana to show data from a mysql database, basically it is VPN connections, I check the database and if I have all the data correct, my program is working and storing correctly in the database , but when I try to see it in the graph I see that it is limiting the data to one million, does anyone know how to increase that size or make it have no limit please?
Try changing this setting:
row_limit
Limits the number of rows that Grafana will process from SQL (relational) data sources. Default is
1000000.
have you touched base with your db admin about fetching so many rows in one query?
