– Using Grafana 8.0.6 running on windows server 2016 virtual machine -
– Query more than 10000 rows of data -
– I couldn’t find any automated way to achieve this, so I have to go back to the date I am interested in and select time range and export the syslog to a css file, than in the same date range, change the time in the same date and export the rest of the data. -
What happened?
– This process is not reliable 100% because I might miss some logs sonf its time consuming because I am receiving tons of data and I would like to fully export the last 3months of data to a single css file -
– Actually I would like to be able to retrieve more than 10k of data, but when I change the limit from 500 to 50.000, for example. I get an error -
– Its just from grafana dashboard, underMetric=>Options -
– If I choose any value higher than 10.000, I get the message that there is no data to be retrieved
