Hello there,
I’m trying to visualize some temperature value in Grafana as part of HomeAssistant.
Surprisingly it was working on the first attempt
…almost…
Unfortunately the SQL query (which I created with the “Query Bilder”) is limited to 50.
Could someone help me to understand where the limit is comming from and how to change it?
Best Regards
Michael
PS: please find the code of the graph below.
| Key | Value |
| Panel | timeseries @ 9.2.4 (64017e8ca6) |
| Grafana | 9.2.4 (64017e8ca6) // Open Source |
Panel debug snapshot dashboard
"panels": [
"id": 2,
"gridPos": {
"h": 13,
"w": 15,
"x": 0,
"y": 0
"type": "timeseries",
"title": "Reproduced with embedded data",
"datasource": {
"type": "grafana",
"uid": "grafana"
"description": "Vor- und Rücklauftemperaturen des Heitzkreis1",
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "line",
"lineInterpolation": "smooth",
"barAlignment": 0,
"lineWidth": 1,
"fillOpacity": 0,
"gradientMode": "none",
"spanNulls": false,
"showPoints": "auto",
"pointSize": 5,
"stacking": {
"mode": "none",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [
"matcher": {
"id": "byName",
"options": "ruecklaufTemp"
"properties": [
"id": "color",
"value": {
"fixedColor": "semi-dark-blue",
"mode": "fixed"
"matcher": {
"id": "byName",
"options": "vorlaufTemp"
"properties": [
"id": "color",
"value": {
"fixedColor": "semi-dark-red",
"mode": "fixed"
"options": {
"tooltip": {
"mode": "single",
"sort": "none"
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
"targets": [
"refId": "A",
"datasource": {
"type": "grafana",
"uid": "grafana"
"queryType": "snapshot",
"snapshot": [
"schema": {
"refId": "A",
"meta": {
"executedQueryString": "SELECT vorlaufTemp, ruecklaufTemp, Timestamp FROM MyHomeDataTest.LWZ8data LIMIT 50 "
"fields": [
"name": "vorlaufTemp",
"type": "number",
"typeInfo": {
"frame": "float64",
"nullable": true
"config": {}
"name": "ruecklaufTemp",
"type": "number",
"typeInfo": {
"frame": "float64",
"nullable": true
"config": {}
"name": "Timestamp",
"type": "time",
"typeInfo": {
"frame": "time.Time",
"nullable": true
"config": {}
"data": {
"values": [
31.4,
32.3,
32.3,
33,
33.1,
33.2,
33.2,
33.5,
33.3,
32.5,
32.5,
33.1,
33.3,
30.7,
30.9,
31.1,
31.1,
31.1,
30.1,
29.5,
29.7,
29.8,
29.8,
29.6,
28.9,
29.1,
28.9,
28.2,
28.3,
28.3,
28.3,
27.9,
27.7,
27.7,
27.8,
27.2,
26.8,
27.6,
27.1,
27.7,
27.9,
28,
28.8,
29.8,
29.8,
29.9,
30.7,
31.3,
32.4,
32.1
29.5,
30.4,
30.4,
30.4,
30.8,
30.7,
30.7,
31.5,
31.3,
30.6,
30.6,
30.9,
31.4,
31.4,
31.6,
31.7,
31.7,
31.3,
30.1,
30.3,
30.5,
30.3,
30.3,
29.9,
29.5,
29.6,
29.1,
28.7,
28.8,
28.8,
28.9,
28.4,
28.3,
28.3,
28.2,
27.3,
25.5,
24.8,
24.5,
24.7,
25,
24.9,
25.2,
25.2,
26,
26.5,
27.4,
27.6,
27.8,
27.8
1669924340000,
1669924369000,
1669924397000,
1669924457000,
1669924517000,
1669924577000,
1669924637000,
1669924741000,
1669924801000,
1669924861000,
1669924921000,
1669924981000,
1669925041000,
1669925148000,
1669925233000,
1669925293000,
1669925353000,
1669925413000,
1669925473000,
1669925533000,
1669925593000,
1669925653000,
1669925713000,
1669925773000,
1669925864000,
1669925924000,
1669926040000,
1669926100000,
1669926160000,
1669926220000,
1669926280000,
1669926388000,
1669926448000,
1669926508000,
1669926568000,
1669926628000,
1669926688000,
1669926760000,
1669926933000,
1669926993000,
1669927053000,
1669927113000,
1669927173000,
1669927233000,
1669927293000,
1669927353000,
1669927413000,
1669927473000,
1669927533000,
1669927593000
"gridPos": {
"h": 7,
"w": 9,
"x": 15,
"y": 0
"id": 5,
"options": {
"content": "<table width=\"100%\">\n <tr>\n <th width=\"2%\">Panel</th>\n <td >timeseries @ 9.2.4 (64017e8ca6)</td>\n </tr>\n <tr>\n <th>Queries</th>\n <td>A[mysql]</td>\n </tr>\n \n <tr><th>Data</th><td> 1 frames, 3 fields, 50 rows </td></tr>\n \n <tr>\n <th>Grafana</th>\n <td>9.2.4 (64017e8ca6) // Open Source</td>\n </tr>\n </table>",
"mode": "html"
"title": "Debug info",
"type": "text"
"id": 6,
"title": "Original Panel JSON",
"type": "text",
"gridPos": {
"h": 13,
"w": 9,
"x": 15,
"y": 7
"options": {
"content": "{\n \"id\": 6,\n \"gridPos\": {\n \"h\": 8,\n \"w\": 12,\n \"x\": 0,\n \"y\": 0\n },\n \"type\": \"timeseries\",\n \"title\": \"Vor- / Rücklauf\",\n \"datasource\": {\n \"type\": \"mysql\",\n \"uid\": \"-ZrW0OF4z\"\n },\n \"description\": \"Vor- und Rücklauftemperaturen des Heitzkreis1\",\n \"fieldConfig\": {\n \"defaults\": {\n \"custom\": {\n \"drawStyle\": \"line\",\n \"lineInterpolation\": \"smooth\",\n \"barAlignment\": 0,\n \"lineWidth\": 1,\n \"fillOpacity\": 0,\n \"gradientMode\": \"none\",\n \"spanNulls\": false,\n \"showPoints\": \"auto\",\n \"pointSize\": 5,\n \"stacking\": {\n \"mode\": \"none\",\n \"group\": \"A\"\n },\n \"axisPlacement\": \"auto\",\n \"axisLabel\": \"\",\n \"axisColorMode\": \"text\",\n \"scaleDistribution\": {\n \"type\": \"linear\"\n },\n \"axisCenteredZero\": false,\n \"hideFrom\": {\n \"tooltip\": false,\n \"viz\": false,\n \"legend\": false\n },\n \"thresholdsStyle\": {\n \"mode\": \"off\"\n }\n },\n \"color\": {\n \"mode\": \"palette-classic\"\n },\n \"mappings\": [],\n \"thresholds\": {\n \"mode\": \"absolute\",\n \"steps\": [\n {\n \"color\": \"green\",\n \"value\": null\n },\n {\n \"color\": \"red\",\n \"value\": 80\n }\n ]\n }\n },\n \"overrides\": [\n {\n \"matcher\": {\n \"id\": \"byName\",\n \"options\": \"ruecklaufTemp\"\n },\n \"properties\": [\n {\n \"id\": \"color\",\n \"value\": {\n \"fixedColor\": \"semi-dark-blue\",\n \"mode\": \"fixed\"\n }\n }\n ]\n },\n {\n \"matcher\": {\n \"id\": \"byName\",\n \"options\": \"vorlaufTemp\"\n },\n \"properties\": [\n {\n \"id\": \"color\",\n \"value\": {\n \"fixedColor\": \"semi-dark-red\",\n \"mode\": \"fixed\"\n }\n }\n ]\n }\n ]\n },\n \"options\": {\n \"tooltip\": {\n \"mode\": \"single\",\n \"sort\": \"none\"\n },\n \"legend\": {\n \"showLegend\": true,\n \"displayMode\": \"list\",\n \"placement\": \"bottom\",\n \"calcs\": []\n }\n },\n \"targets\": [\n {\n \"dataset\": \"MyHomeDataTest\",\n \"datasource\": {\n \"type\": \"mysql\",\n \"uid\": \"-ZrW0OF4z\"\n },\n \"editorMode\": \"builder\",\n \"format\": \"table\",\n \"rawSql\": \"SELECT vorlaufTemp, ruecklaufTemp, Timestamp FROM MyHomeDataTest.LWZ8data LIMIT 50 \",\n \"refId\": \"A\",\n \"sql\": {\n \"columns\": [\n {\n \"parameters\": [\n {\n \"name\": \"vorlaufTemp\",\n \"type\": \"functionParameter\"\n }\n ],\n \"type\": \"function\"\n },\n {\n \"parameters\": [\n {\n \"name\": \"ruecklaufTemp\",\n \"type\": \"functionParameter\"\n }\n ],\n \"type\": \"function\"\n },\n {\n \"parameters\": [\n {\n \"name\": \"Timestamp\",\n \"type\": \"functionParameter\"\n }\n ],\n \"type\": \"function\"\n }\n ],\n \"groupBy\": [\n {\n \"property\": {\n \"type\": \"string\"\n },\n \"type\": \"groupBy\"\n }\n ],\n \"limit\": 50\n },\n \"table\": \"LWZ8data\"\n }\n ]\n}",
"mode": "code",
"code": {
"language": "json",
"showLineNumbers": true,
"showMiniMap": true
"id": 3,
"title": "Data from panel above",
"type": "table",
"datasource": {
"type": "datasource",
"uid": "-- Dashboard --"
"gridPos": {
"h": 7,
"w": 15,
"x": 0,
"y": 13
"options": {
"showTypeIcons": true
"targets": [
"datasource": {
"panelId": 2,
"withTransforms": true,
"refId": "A"
"schemaVersion": 37,
"title": "Debug: Vor- / Rücklauf // 2022-12-01 22:51:00",
"tags": [
"debug",
"debug-timeseries"
"time": {
"from": "2022-12-01T12:15:33.295Z",
"to": "2022-12-02T00:15:33.295Z"
