Grafana 10.4.1
InfluxDB 2.7.5-alpine
SqlServer 2019
- What are you trying to achieve?
I have series in InfluxDB that represent sensors measurements. The details of these measures (from which sensor, what is measured, ect…) is stored in a SQL DB.
In grafana, I would display the measures (Influx) and as display name their description (SQL). So make a join on the column ‘measure_id’.
Exemple of serie :
SQL result :
What I want to change :
- How are you trying to achieve it?
I tried to merge the queries with transformations
- What happened?
Any hint to display timeseries with their details from 2 different sources ?
