JOIN InfluxDB V3 and MS-SQL data
    V12.0.0
    I want to join data from an InfluxDB v3 DB with SQL query and data from MS-SQL and display multiple series with respect to their id and have their description in the legend.
    Using INNER JOIN transformation
  • What happened?
    The join is made correctly
    I expected to have multiple series (with respect to their id) and instead of “_value” name, I would like to display the description of the serie.
I tried to change the display name with “${__field.labels.description}” but it doesn’t work and do not fix the multiple serie issue.
Any idea ?
Regards
Stéphane
Ok I added an Partition by values transformation
And with the Display name : ${__field.labels.description}
it works
Regards
Stéphane
