I am trying to plot the InfluxDB series on Grafana as a table.
I am trying to plot the series using the Time series and Graph panel.
it coming as a table but I am trying to join two series
It should plot on table and tags, fields should come as a column.
InfluxDB dashboard. four columns are coming.
For the same query, the Grafana panel shows this result.
as you can see in Grafana. It showing as multiple series.
Is there anyway we can plot same like InfluxDB?
