Docker on v8.3.1 -
Table of multiple field Last values from influxdb query so all 7 fields are displayed as columns for a given tag. -
Pivoting the influxdb query around a tag variable. -
What happened?
One row in my table, with columns correct, and a selector for each tag value at the bottomw of the table. -
Not really sure… how exactly Grafana interprets the results from Influx is still a mystery to me… I really want a single table with all stations visible simultaneously. -
from(bucket: "cah2")
|> toFloat()
|> last(column: "_value")
|> map(fn: (r) => ({ r with _measurement: r.stationName }))
|> group(columns: ["_measurement"])
|> pivot(rowKey:["_measurement"], columnKey: ["_field"], valueColumn: "_value")
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No. - Did you follow any online instructions? If so, what is the URL?
No.
When I try to apply a Merge transformation I get all the rows, but then they don’t have a station name on each row…
