Table: joining MS SQL and InfluxDB queries
    v8.0.3 (cae5c5e46b)
    Windows 10
    In a table panel, I have several queries on a MS SQL source and would like to join a query on an InfluxDB (v0) source on a common field.
    I have used the Outer join Transform.
  • What happened?
    The Outer join Transform works among the SQL queries, but when the InfluxDB query is added the join doesn’t happen and all the SQL query results disappear from the table.
    I’d expect that the InfluxDB query results would be added to the table as with the other queries
    For example, the SQL queries are like:
SELECT [SiteName]
      ,[SiteDescription]
  FROM [foo].[bar].[bas]
The InfluxDB query is
SELECT count("value")
FROM "event"
WHERE $timeFilter
GROUP BY "SiteName"
And the Outer join is done on the field SiteName
    N/A
    I’ve looked up resources s but none was specifically about this issue
Just to add:
Return from the MS SQL query
Return from the InfluxDB query
@felipefischmann Hii can you tell me, did you achieve the above thing? and if yes how? I would like to join Influx data and Mysql data in single table
I suppose there is same value in the two columns “SiteName” ?
have you the same key type from the two datasources ?
please share us your data format and more information
Somehow it works, no changes from what was described above
It only works however when both queries are formatted as Table. Ideally I’d like to have the bottom query formatted as a series to use in a Heatmap panel: the goal would be to use the SiteDescription instead of the SiteName as the metric name, but in InfluxDB they are stored as the SiteName.
