Merge transformation
    7.5.11
    i am trying to use the merge transformation or outer join transformation to join 12 query results in a table. some of the queries is not returning any data. so the entire table is blank even though some of the queries have data. I am trying to figure it out what else I can do to get the data displayed
    query 1 - results in table
    query 2 - results in table
    query 3 - results in table
Merge transformation on common field, outerjoin on common field
  • What happened?
    displaying bad gateway
it is solved, the queries taking longer time and data source post method was able to fix my issue.
