Merging queries in table
    9.0
    Instead of going to new line i would like each query to create columns
time name psuindex Value #A name#b psuindex#b Value #B name#c psuindex#c Value #c name#d psuindex#d Value #D
2024-11-04 16:03:18.986 temperature1 1 46 temperature2 1 60 fanRPM1 1 4160 fanRPM2 1 0
2024-11-04 16:03:18.986 temperature1 2 44 temperature2 2 61 fanRPM1 2 4160 fanRPM2 2 0
2024-11-04 16:03:18.986 temperature1 3 0 temperature2 3 0 fanRPM1 3 4160 fanRPM2 3 0
2024-11-04 16:03:18.986 temperature1 4 0 temperature2 4 0 fanRPM1 4 4160 fanRPM2 4 0
    i enter the queries and add merge transform
  • What happened?
    Each query creates 4 new lines instead of columns
2024-11-04 16:03:18.986 temperature1 1 46 temperature2 1 60 fanRPM1 1 4160 fanRPM1 1 0
2024-11-04 16:03:18.986 temperature1 2 44 temperature2 2 61 fanRPM1 2 4160 fanRPM1 2 0
2024-11-04 16:03:18.986 temperature1 3 0 temperature2 3 0 fanRPM1 3 4160 fanRPM1 3 0
2024-11-04 16:03:18.986 temperature1 4 0 temperature2 4 0 fanRPM1 4 4160 fanRPM1 4 0
    No
    Used google to find something but without success
Try join transformation and join result by using psuindex column
Can you elaborate more please
Thank you!
