Grafana v11.3.0+security-01 (5ddc329279) / Ubuntu Linux -
Merge same columns -
Tried different transformations -
What happened?
Didn’t get desired result -
Expect to have columns with same name merged. -
No -
Hi, i have a metric of following type: worker{metric="metric_name", replica="replica_id"}.
Querying different values of metric label will result in different metrics of some worker. As u can see on screenshot 1, currently my table has duplicated columns with same purpose. They are separated because of 2 different replicas of my service, and i want to get these 2 merged under single column, mb it could have separate column with replica_id.
Currently it has these transformations applied
Also i’m not sure how to get rid of duplicate rows, i thought about grouping by scheduled_start, but it means that 2 different replica entries will be grouped too?
