I am using Grafana 9.4.7 on a RHEL 8.x VM -
I have 2 metrics JvmActiveTotal and JvmInactiveTotal, each with the same label “env” containing dev / qa / uat.
The “historical information” is irrelevant, only the last value needs to be shown
I want a table with 2 rows JvmActiveTotal and JvmInactiveTotal and dynamic columns per environment (dev / qa / uat) -
I tried as follows
- table panel
- 2 queries (1 per metric) : Format Table + Type Instant
- Transformation : Group By Matrix : Column=“env” Row=“name” Cell Value =Value
- What happened?
When only first query is defined, the result is ok : 1 row, with three columns, with correct values (without timestamp)
When second query is added to the panel, the table shows timestamp and all labels with a “listbox” at the bottom where I can select Value A or Value B.
I tried to resolve by adding a Merge Transformation first before the Group By Matrix,
The Group By Matrix now requires Value to be either Value #A or #B.
Now 2 rows appear , but only one of the rows contains the actual correct values : the other row contains blanks.
When using a [Merge Transf. + Reorganize + Group By matrix ] with the reorganize to rename Value #A and Value #B to “Val”, the column headers are not dev / qa / uat but three times Val.
I would expect a “merge transformation” that would place the actual values in the same “Value” variable , so that it can be displayed correctly.
Or is there a better approach to display results of different queries in 1 overview with the values of a label as columns?
