Concatenate multiple queries as rows instead of column
    Grafana 11.20
    Multiple queries to rows
    Using concatenate fields
  • What happened?
    Multiple queries concatenated to column
    Multiple queries concatenated as rows
    No
    No
I have a query that looks like this:
I want it to show all the queries in one table, so i use the concatenate fields. But it combines the query to column instead of row
What i want is like this:
Does anyone have an idea how?
i got it close:
Hi, not a tested solution but wouldn’t using just the Merge transformation suffice? You might need to play around with column naming first (organize fields transformation with filters) so that the columns names are the same but I think it could work.
are both data sources mysql and both on the same server?
Both are from different postgresql database, but have the same column name. I managed to get it like this:
But it adds suffix to column name like 1 and 2 (lastlogin 1, lastlogin2, active1, active2).
What i want to achieve is something like this:
Sorry for the trouble, i manage to solve it using the query above and this transformation:
Thank you all for responding.
