Join 2 queries (mssql)
I work with 2 separates servers with MSSQL.
I need join 2 results queries in a bar gauge visualization.
QUERY A
QUERY B
I need a result table with this columns
ID_ORIGEN
ORIGEN
CANTIDAD
I cant understand how it is so dificult.
Help pls, thanks in advances.
    v 11.4 - Docker
    Join 2 queries from 2 diferents mssql servers
    Whatever
  • What happened?
    I cant
    Work
    N/A
    N/A
    A lot
It shouldn’t be difficult. Are you using Join by field transformation? The only tweak is what you want to present - inner or outer join (work just like in databases).
Thank you very much for your reply.
I swear that I have done and redid what you sent me a thousand times and it does not work for me.
I managed to make it work with a “merge series/tables” + “group by” + “organize fields by name”.
I really appreciate you replying.
A big hug and have a great end of the year.
I think there is one difference - what’s the type of your ID_ORIGEN field? As you can see in my screen I picked the one with (base field name) but my fields are both String Types. As I can see in your query, it’s a string type in the table but Grafana renders the join transformation as it was number - maybe it can’t join on fields with same name but different types?
For performance reasons I ended up asking them to create the destination table in the same database (it wasn’t very big and it also greatly improves the performance of the query).
But now that I read your answer I think it is as you say, ID_ORIGEN is an extraction of a field that contains a JSON and that through a view it was converted into a varchar type column.
And the other query did have the ID_ORIGEN as an integer.
Surely the problem was there although I remember having used the CAST(ID_ORIGEN AS INT) and anyway it did the same thing to me.
Anyway you made me understand how some things work and I value it very much.
Hugs.-
