Grafana 8.4.6
CentOS 7.8 -
Use an existing dashboard from another organization -
- Exported the dashboard from one organization
- Switched to the new organization
- Imported the dashboard
- All the panels show up but no data shows in the graphs
- What happened?
- The data comes from an InfluxDB. The connection to InfluxDB in Grafana has been configured and tested. All the buckets from InfluxDB are showing up when the query is formulated.
No errors. -
Yes, from the official documentation
Manage dashboards | Grafana documentation
