I exported a dashboard from one grafana instance and am trying to import to another. When I import, it then asks me for an elasticsearch datasource, which I put in, but then it also asks me for a testdata DB and since there are none and it doesnt let me import. please help.
Hi @hivadruid there might have been a panel in the dashboard you exported that had Testdata DB which is Grafana’s test date source that helps you experiment with visualizations with mocked up data. If you’re using version 7+ it should show up as a regular data source: https://grafana.com/docs/grafana/latest/features/datasources/testdata/
