I need to dashboard and panels export from one server to another server.
Both servers configured and Tested DB path Influx-db. Both server same DB only configured.
My worries i couldn’t export Dashboard with inside all panels to import 2nd server.
Hi harikrishnan
Check if your datasources are exactly the same, maybe in the the datasource names differ between the Grafana instances. Or in your origin dashboard is “Default” selected as datasource and in your destination Grafana is a different “Default” datasource configuered.
Best regards
Malte
Hi Malte
Yes, You are correct.
I forget to make default correct db source.
Now working fine.
Thank you
