I ask how you can import in a programmatic way dashboards to another environment.
Is related to this issue in Github [Grafana] 8.3.X Copy a Dashboard to another environment by copying it from Json Model · Issue #43440 · grafana/grafana · GitHub
I run a Powershell to Get all Dashboards and Folders and be able to import them in another enviroment(We used to do it for Grafana Version 4.6 and since the datasource was a simple string in the dashboard json, it give no problem).
I paste here the script
$user = 'xxxx'
$pass = 'xxxx'
$port = 8080
$server = 'xxxxxxx'
$outputPath = "$PSScriptRoot\output"
$outputFolderPath = "$([System.IO.Path]::Combine($outputPath,"001_Folder"))";
$outputDashboardPath = "$([System.IO.Path]::Combine($outputPath,"002_Dashboard"))";
$searchForAlarmsDashboards = $false;
rm -Path $outputPath -Recurse
New-Item -ItemType Directory -Force -Path $outputPath > $null;
New-Item -ItemType Directory -Force -Path $outputFolderPath > $null;
New-Item -ItemType Directory -Force -Path $outputDashboardPath > $null;
$Headers = @{
Authorization = "Basic $([System.Convert]::ToBase64String([System.Text.Encoding]::UTF8.GetBytes("$($user):$($pass)")))"
$folders = Invoke-RestMethod -Uri "http://$($server):$($port)/api/folders" -Method Get -Headers $Headers -ContentType 'application/json';
$folders | % {
$folder = New-Object System.Object;
$folder | Add-Member -NotePropertyName uid -NotePropertyValue $_.uid;
$folder | Add-Member -NotePropertyName title -NotePropertyValue $_.title;
$folder | ConvertTo-Json | Out-File "$($outputFolderPath)\$($_.uid).folderjson";
$apiDashboardUri = "http://$($server):$($port)/api/dashboards";
$dashboards = Invoke-RestMethod -Uri "http://$($server):$($port)/api/search/?type=dash-db" -Method Get -Headers $Headers -ContentType 'application/json';
$dashboards | ? {($searchForAlarmsDashboards -and ($_.tags.Contains("alarms"))) -or (-not $searchForAlarmsDashboards -and (-not $_.tags.Contains("alarms")))} | % {
$dashboard = Invoke-RestMethod -Uri "$($apiDashboardUri)/uid/$($_.uid)" -Method Get -Headers $Headers -ContentType "application/json";
$panelBody = New-Object System.Object;
$panelBody | Add-Member -NotePropertyName dashboard -NotePropertyValue $dashboard.dashboard;
$panelBody | Add-Member -NotePropertyName folderUid -NotePropertyValue $dashboard.meta.folderUid;
$panelBody | Add-Member -NotePropertyName overwrite -NotePropertyValue $true;
$panelBody | ConvertTo-Json -Depth 100 | Out-File "$($outputDashboardPath)\$($_.uid).json";
A part of the panelBody has an uid that identifies the Datasource (That usually changes between the different enviroments).
Do I have to export the databases as well in order to change the uid of the equivalent databases in the new enviroment? (Before creating the Dashboards).
This is the only solution that I see but I see that in the database api you can change the uid easily so I think that it is the only solution
$user = 'xxxxxx'
$pass = 'xxxxx'
$port = 8080
$server = 'xxxxxx'
$outputDbPath = "$([System.IO.Path]::Combine($outputPath,"002_DB"))";
$outputDashboardPath = "$([System.IO.Path]::Combine($outputPath,"003_Dashboard"))";
$mainUrl = "http://$($server):$($port)"
New-Item -ItemType Directory -Force -Path $outputDbPath > $null;
$Headers = @{
$folders = Invoke-RestMethod -Uri "$($mainUrl)/api/folders" -Method Get -Headers $Headers -ContentType 'application/json';
$folders | % {
$folder | ConvertTo-Json | Out-File "$($outputFolderPath)\$($_.uid).folder";
$dbs = Invoke-RestMethod -Uri "$($mainUrl)/api/datasources" -Method Get -Headers $Headers -ContentType 'application/json';
$dbs | % {
$db = New-Object System.Object;
$db | Add-Member -NotePropertyName name -NotePropertyValue $_.name;
$db | Add-Member -NotePropertyName uid -NotePropertyValue $_.uid;
$db | ConvertTo-Json | Out-File "$($outputDbPath)\$($_.name).db";
$dashboards = Invoke-RestMethod -Uri "$($mainUrl)/api/search/?type=dash-db" -Method Get -Headers $Headers -ContentType 'application/json';
$dashboard = Invoke-RestMethod -Uri "$($mainUrl)/api/dashboards/uid/$($_.uid)" -Method Get -Headers $Headers -ContentType "application/json";
Finally this is the script that I use for BackUp the Dashboards and Folders from the master environment:
$user = 'xxxxxx';
$pass = 'xxxxxx';
$port = 8080;
$server = 'xxxx';
$outputPath = "$PSScriptRoot\output";
$mainUrl = "http://$($server):$($port)";
rm -Path $outputPath -Recurse -ErrorAction SilentlyContinue;
if(-not $searchForAlarmsDashboards){
$changelogStringBuilder = [System.Text.StringBuilder]::new();
$changelogStringBuilder.AppendLine("# $packageName") > $null;
$changelogStringBuilder.AppendLine("Package of all default grafana panels") > $null;
$changelogStringBuilder.AppendLine("") > $null;
$changelogStringBuilder.AppendLine("## [$nugetVersion] - $(Get-Date -format yyyy-MM-dd)") > $null;
$changelogStringBuilder.AppendLine("### Changed") > $null;
$changelogStringBuilder.AppendLine("- $nugetVersionReleaseNotes") > $null;
$changelogStringBuilder.AppendLine("### Added") > $null;
$Headers = @{
Write-Host "Getting folders";
$folders | % {
$folder | ConvertTo-Json | Out-File ([System.IO.Path]::Combine($outputFolderPath,"$($_.uid).folder"));
$changelogStringBuilder.AppendLine("- Folder $($_.title)") > $null;
Write-Host "Getting Dbs";
$dbs | % {
$db | ConvertTo-Json | Out-File ([System.IO.Path]::Combine($outputDbPath,"$($_.name).db"));
Write-Host "Getting Dashboards";
$changelogStringBuilder.AppendLine("- Dashboard slug: $($dashboard.meta.slug), updated: $($dashboard.meta.updated), updatedBy: $($dashboard.meta.updatedBy), version: $($dashboard.meta.version) uid: $($_.uid)") > $null;
$dashboard | ConvertTo-Json -Depth 100 | Out-File ([System.IO.Path]::Combine($outputDashboardPath,"$($_.uid).json"));
Add-Content ([System.IO.Path]::Combine($outputPath,"changelog.txt")) $changelogStringBuilder.ToString();
And this is the script that I have for Importing them:
$inputPath = "$PSScriptRoot"
if(-not(Test-Path -Path $inputPath)){
Write-Error "This path: $inputPath not found"
return;
$Headers = @{
Authorization = "Basic $([System.Convert]::ToBase64String([System.Text.Encoding]::UTF8.GetBytes("$($GrafanaAdminUser):$($GrafanaAdminPassword)")))"
$mainUrl = "http://$($GrafanaNotificationChannelsServer):$($GrafanaHttpPort)";
$health = Invoke-RestMethod -Uri "$($mainUrl)/api/health" -Method Get -Headers $Headers -ContentType "application/json";
$versionGrafana = $null;
if([version]::TryParse($health.version, [ref] $versionGrafana)){
Write-Host "Version in Grafana is $versionGrafana";
$minVersionWithFolders = [version]::new(8,0,0);
if($versionGrafana.CompareTo($minVersionWithFolders) -ge 0){
Write-Host "Version in Grafana is $versionGrafana which is greater than $minVersionWithFolders";
#Reading Folder its necesary to create the dashboard in the correct folder
$foldersInGrafana = Invoke-RestMethod -Uri "$($mainUrl)/api/folders" -Method Get -Headers $Headers -ContentType 'application/json';
ls -Path "$inputPath\*.folder" -Recurse | % {
$folder = [System.IO.File]::ReadAllText($_.FullName) | ConvertFrom-Json;
$folderInGrafana = $foldersInGrafana | ? {$_.title -eq $folder.title};
if($folderInGrafana -eq $null){
Write-Host "Creating folder $($folder.title)";
Invoke-RestMethod -Uri "$($mainUrl)/api/folders" -Method Post -Headers $Headers -ContentType "application/json" -Body ($folder | ConvertTo-Json);
else{
Write-Host "Folder already exist in grafana";
#Reading datasources its necesary to update uid of the datasource because its written in the dashboard
$dbsInGrafana = Invoke-RestMethod -Uri "$($mainUrl)/api/datasources" -Method Get -Headers $Headers -ContentType 'application/json';
ls -Path "$inputPath\*.db" -Recurse | % {
$db = [System.IO.File]::ReadAllText($_.FullName) | ConvertFrom-Json;
$dbInGrafana = $dbsInGrafana | ? {$_.name -eq $db.name};
if($dbInGrafana -eq $null){
Write-Host "Db $($db.name) does not exist in Grafana";
else{
Write-Host "Db $($db.name) does exist in Grafana updating uid";
$dbInGrafana.uid = $db.uid;
Invoke-RestMethod -Uri "$($mainUrl)/api/datasources/$($dbInGrafana.id)" -Method Put -Headers $Headers -ContentType "application/json" -Body ($dbInGrafana | ConvertTo-Json);
else{
Write-Host "Version in Grafana is $versionGrafana which is lower than $minVersionWithFolders";
ls -Path "$inputPath\*.json" -Recurse | % {
$dashboard = [System.IO.File]::ReadAllText($_.FullName) | ConvertFrom-Json;
$dashboardBody = New-Object System.Object;
$dashboardBody | Add-Member -NotePropertyName dashboard -NotePropertyValue $dashboard.dashboard;
if($dashboard.meta.folderUid -ne $null){
$dashboardBody | Add-Member -NotePropertyName folderUid -NotePropertyValue $dashboard.meta.folderUid;
$dashboardBody | Add-Member -NotePropertyName overwrite -NotePropertyValue $true;
$dashboardBody.dashboard.id = $null; #Eliminamos los id, para poder importar.
Write-Host "Creating dashboard:$($dashboardBody.dashboard.title) Folder:$($dashboardBody.folderUid)";
Invoke-RestMethod -Method Post -Headers $Headers -ContentType "application/json" -Uri "$($mainUrl)/api/dashboards/db" -Body ($dashboardBody | ConvertTo-Json -Depth 100 );
Write-Host "Updating dashboard:$($dashboardBody.dashboard.title) Folder:$($dashboardBody.folderUid)";
## Invoke twice to make the alarms start
else{
write-Error "Not parsed version in Grafana";
I think that both are valid, but I need to know if this is the correct form of importing and exporting dashboards and folders.
Dbs are being created earlier in the process so when you import the dashboards you have to make sure that all the dbs have the same uid
Thanks for your example. I’m new in powershell and grafana.
I need to export all dashboard but when i launch this :
$folders = Invoke-RestMethod -Uri “$($GrafanaURL)” -Method Get -Headers $Headers -ContentType ‘application/json’; , $folders is empty and with a curl i have this message : unauthorized.
Can you help me ?
Many thanks.
Will
Hi @wilfridrussodivito
It seems that the user and password are not correct.
So you have a Unauthorized response. Take into account that this was a question and it was never answered (It is not an official solution), if you want to just copy a dashboard to other environment and you have few environments this could not be the solution.
But the company I worked for had over 50 panels and over 20 platforms and we wanted a way to automatize it.
jgarciadelanoceda:
dashboards
Many thanks.
Is it possible to loop on each grafana’s folder and for each folder, export in json all dashboard ?
i tried to adapt your code but it don’t work.
Are you trying to move dashboards to a new server?
No. The goal it’s to export all folders (and all dashboards) from grafana in json file (for the dashboards) and import all this in Team Foundatiom server.
On grafana, the structure is like this :
folder 1
dashboard 1
*dashboard 2
folder 2
dashboard 1
*dashboard 2
etc etc
Hello @yosiasz ,
It is not to move the dashboards to a new server what I originally wanted, what I wanted is to replicate the same dashboards and folders structure in another Grafana deployment.
The company I worked for had over 20 platforms were we did Monitoring using Grafana and InfluxDb, we wanted to have the same dashboards in all of them
Here is what I wrote in python. The basic idea can be done in any other scripting language
import requests
import json
from dotenv import load_dotenv
load_dotenv()
import os
TOKEN=os.getenv('TOKEN')
URL=os.getenv('URL')
headers= {
'Accept': 'application/json',
'Content-Type': 'application/json',
'Authorization': 'Bearer {}'.format(TOKEN)
r = requests.get(url = URL, headers = headers)
for d in r.json():
uid = d.get('uid')
title = d.get('title')
This file has been truncated. show original
yosiasz
December 2, 2022, 2:09pm
10
If you want to replicate the same structure it sounds like moving to me
In that case what I do is copy the data and conf folder to the secondary server and restart grafana - done
Thanks,
but how do you put in URL variable : https://yourgrafana/ with api or something else ?
As Javier said, I wanted is to replicate the same dashboards and folders structure in TFS.
Loop on folders is ok, but loop on each dashboard of each folder : i can’t do it
Could you explain the solution a little bit more?
I think that this could be interesting for the rest of the community
Yes : i need to import the structure of Grafana (only folders and dashboards) in Team Foundation Server. For the moment i loop on Grafana’s folders and for each folder, i create it on Windows like this :
$folders | % {
$DashboardsDir = $outputFolderPath + "" + $.title
New-Item -ItemType Directory -Force -Name $ .title -Path $outputFolderPath;
On this loop, i need to get all dashboards of the current folders and create one json file per dashboards found on the current folder but i don’t know how to do this.
Have you got an idea ?
This was my original Idea
So @wilfridrussodivito check the dashboards importing scripts, because it is what it does (Although if you had already the same folderId with different Uid in the destination I think that the solution could have a problem)
I do not have access to the environments anymore so I am not updating the solution
It is also important to say that the databases in the destination environment were deployed in a previous step of the pipeline
yosiasz
December 2, 2022, 2:26pm
18
Importing to a different instance of grafana via script?
Yes
It was my only goal I had
Are the datasources also being copied (Just for curiosity?)
Yeah now it seems a complicated solution
yosiasz
December 2, 2022, 2:41pm
22
In which of the 2 solutions?
The one you copy data and conf folders
