I use Grafana V8.5.13. I’m new in powershell and Grafana.
I want to export all dashboards with a powershell script. When i want to do a curl :
curl MyUrl/api/folders/
i have this message :
{“message”:“Unauthorized”}
Thanks in advance.
Wilfrid
Thanks in advance.
Wilfrid
Hello
Have you rewd the following documentation?
Yes, all HTTP API documentation.
Will
on Chrome when i type MyUrl/api/folders, i have what i want :
[{“id”:24,“uid”:“vFCSdTNVk”,“title”:“Business”},{“id”:23,“uid”:“h9i97TH4k”,“title”:“ISO - Monitoring”},{“id”:20,“uid”:“9A6jMoNVz”,“title”:“ISO - Windows”},{“id”:1,“uid”:“po8qW8fMk”,“title”:“Monitoring - Alerts”},{“id”:8,“uid”:“pFfHMUBMz”,“title”:“Monitoring Infrastructure”}]
But to do it programatically it is abiy different you need to provide authorization bearer token
oh yes, here my powershell code :
$GrafanaURL = MyGrafanaURL/api/folders"
[String]$Key = MyKey
$Headers = @{ Authorization = “Bearer $($Key)”}
$folders = Invoke-RestMethod -Uri $GrafanaURL -Method Get -Headers $Headers -ContentType ‘application/json’;
Write-Host $folders
And the result is that $folders is empty.
You want dashboards right per original post?
"want to export all dashboards with a "
Yes the goal is to export all dashboards in json or csv format from all my folders.
I use this :
Thanks for your help.
Check this out its with python but you can port the idea to powershell
Many thanks for your help
what is the purpose of this effort? What are you trying to solve?
I started a new job and i’m new in powershell. The goal it’s to import all dashboards in TFS.
another option is to also backup the following folders
data
conf
